On 19/02/2006 at 11:40, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.0+ Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- Howdy,
Here's the problem: From a CommandData plugin, I'm adding 3 tags to the document and making one of them the active tag. This is all being done between a StartUndo()/EndUndo() call, but setting the tag as the active tag is not being logged into the undo group, and it takes two undos to undo the command.
doc->StartUndo(); //...allocate and add tagA code here doc->AddUndo(UNDO_NEW,tagA); //...allocate and add tagB code here doc->AddUndo(UNDO_NEW,tagB); //...allocate and add tagC code here doc->AddUndo(UNDO_NEW,tagC); doc->SetActiveTag(tagB); doc->EndUndo();
I see there is an UNDO_ACTIVATE flag, but the SDK documentation says this: **UNDO_ACTIVATE
Automatically managed by SetActiveObject()/Tag()/Material() etc. No need to use manually.**
But it doesn't seem to add it to the undo group. I did try adding the line:
doc->AddUndo(UNDO_ACTIVATE, tagB);
...both before and after the SetActiveTag() call, but neither one had an effect, and it still takes two undos to undo the command.
Any ideas?
Adios, Cactus Dan
On 20/02/2006 at 04:32, xxxxxxxx wrote:
Perhaps it makes a difference if you reverse the order to:
.. create tagB doc->SetActiveTag(tagB) doc->AddUndo(UNDO_NEW,tagB)
you could also try to set the active bit manually.
.. create tagB doc->AddUndo(UNDO_NEW,tagB) doc->AddUndo(UNDO_ACTIVEATE,tagB); tagB->SetBit(ACTIVE_BIT);
i think this will most likely work. As well as this:
.. create tagB tagB->SetBit(ACTIVE_BIT); doc->AddUndo(UNDO_NEW,tagB)
but then you loose all the convenience of SetActiveTag(). Perhaps you must write your own SetActiveTag which adds all the selection undos to your undo block.
On 20/02/2006 at 16:56, xxxxxxxx wrote:
Howdy,
Thanks Michael, for the reply, but I've since discovered that it's something else that's wrong, because if I comment out the line...
//doc->SetActiveTag(tagB);
...it still needs two undos to undo the command. :o(
I'm wondering if there is a problem because the actual program flow is like this:
create tagA create tagB branch to initialize data in tagB create tagC
... I reckon I better put on the debugging hat.
On 20/02/2006 at 17:21, xxxxxxxx wrote:
AHA!
I found the problem. It seems that you can't have a StartUndo()/EndUndo() nested within a StartUndo()/EndUndo(). The problem is that after adding tagC, I'm sending a MSG_DESCRIPTION_COMMAND to tagC to simulate the pressing of a button, but within that button's routine in tagC, there is another StartUndo()/EndUndo() group. If I don't send the message, then undoing the command works fine with only one undo.
I reckon I'll have to add a separate routine to handle invoking that button from the command tool. ;o)
