First Steps with Visual C++ Express + SDK
On 09/02/2006 at 07:07, xxxxxxxx wrote:
Cinema 4D Version:   9.5
Platform:   Windows  ;
After programming in Coffee I try my first steps in VC++.
There is a free version from microsoft: visual C++ express
I install VC++ and make a renamed copy of SDK-Folder in the Plugins folder in c4d.
Now I start the file: "cinema4dsdk.vcproj"
At ask to convert i say yes!
My first learning steps into a new language is, change running exist code with my ideas.
Second steps are write simple program.
Third is to fill this program with other codesnips.
My problem is, I start the debugger and the debugger say:
"LINK : fatal error LNK1104: Datei "odbc32.lib" kann nicht geöffnet werden" -> can't open
I copy the SDK-folder because, this is the first way, how to I get a .cdl file!
But what can I delete from the sdk-project to get the lowest running program?
I think to a program like this:
#include <iostream.h>
void main()
cout<< "C++ Plugin loaded...";
debugging and running an shown in the console !?
I have a C++ Startup-Book and read it two times.
Is there a better way to start with my first C++ plugin ?
On 10/02/2006 at 11:52, xxxxxxxx wrote:
moin,
go to the project of the plugin settings... search the linker settings... and remove odbc32.lib odbccp32.lib from
library modules... ok tried it only with the 9.1 sdk... but give it a try...
just tried it now... it links even without these libraries...
greetz ultra
