Tag-Plugin with Attributes
On 08/02/2006 at 08:00, xxxxxxxx wrote:
Cinema 4D Version: R9.5
Platform: Windows ;
Language(s) : C.O.F.F.E.E ;---------
Hello all Coders :-)
I can do a Tag-Plugin and I can do a Menuplugin.
But I don't know how can I do a Attributemenu for the Tag-Plugin.
Please Help me...
On 08/02/2006 at 13:23, xxxxxxxx wrote:
Do you mean information in the Attribute Manager?
This is done in two ways:
1. Statically: by defining the .res, .str, and .h files that define the Descriptions for the Tag. Say you have a TagPlugin given Tmytag, then you need a Tmytag.h, Tmytag.res, and Tmytag.str, the latter go into the 'res/description' and 'res/strings_XX/description' folders, respectively.
2. Dynamically: by creating description types and adding to the description. In C++, this is accomplished with GetDDescription(). No idea about COFFEE.
If you only need static description resources, you just create a header with an enum for the .res elements. See "Description Resource" in the C++ SDK Docs for information on what is in the .res file (very similar to Dialog resources, but not identical). The .str file contains strings for your description elements, basically text for buttons, boxes, groups, etc.
On 09/02/2006 at 06:45, xxxxxxxx wrote:
Thanks for replay :-)
I need only a static menu.
It sounds like a Tag has a Layout like a Menu-Plugin.
The Menu-Plugin call Layout for define the Attributes of the Menu, optional I can use .res for describe Attributes.
Is it the same in Coffee ?
PS: I get first Steps in C++ with Visual C++ Express and hope, that I can do it in C++ in few days. Hope ! But I get start trouble ...
