On 31/01/2006 at 02:32, xxxxxxxx wrote:
Cinema 4D Version: 9.1
Platform: Windows ;
Language(s) : C++ ;
hi there...
i'm very new to the cinema api...started just 2 days ago to work with it... hmm but the api description is sometimes a bit confusing to me...
yes... i hear you cry not again animateobject/keyframes... of course
i used the search function of the forum...i read all forum posts about this more than once... and searched the net.. but somehow it did't help me...
what i'm working on a small export filterplugin into a
custom format...
so far it works to export polys/points and uv data...
my goal was to export the animation key frames too...
1. try to get the animation stuff:
first of all i tried to do it in coffee... with iterating
via GetFirstTrack->GetFirstSequence->GetFirstKey and stuff...
that worked so far... but i could not figure out what kind of
keys i've got...hm
beside this i updated to a newer cinema version (9.1) and my the script was overwritten by the installer... very cool feature... so all my work was lost
anyway so i skipped coffee and tried to do it in c++...i was hoping maybe i can get more infos about the key i get back from the BaseSequence...
2. try
now using the c++ api... exporting polys/points/uv are working so far... no problem because of the stl plugin help ;9
but always i get a NULL pointer from GetFirstTrack...(from object or document doesn't matter)
of course there is an animation in the document i can see the keys in the
timeline window... the scene has only one object with a movement and rotation...
so i gave up iterating the keys and tried to do it via animateobject...
3. try
(pseudo code... unfortunately i don't have the source here so i'm writing it just from my mind i did not compile it...maybe some typos in it... but this is just to illustrate what i tried)
variable i goes from... pDoc->GetMinTime()*pDoc->Fps() to pDoc->GetMaxTime()*pDoc->Fps()
BaseTime time( i/pDoc->GetFps() );
pDoc->AnimateObject( pObj, time, ANIMATE_NO_PARTICLES );
when i access for example..
pObj->GetPos() / pObj->GetRot()
also tried pObj->GetMl() or pObj->GetMg()
there is no change... ok maybe correct...
then i tried to get the data via GetAnimatedParameter... very like the example in the docu...
GetAnimatedParameter(DescLevel(ID_OBJECT_POSTION),s1,s2,mix,0);
Vector pos1 = s1.GetVector();
Vector pos2 = s2.GetVector();
that vectors are looking good... but mix is always 0 ? this is what i can't see...
i checked the time and it looks good too... my sequence has 90 frames so it runs from 0 to 3 (30 fps)...
so now my questions...
a) is it correct that i always get a NULL pointer from getfirsttrack ? i remember i read in the forum getfirsttrack doesn't work anymore
with version x.x of cinema ? if so is there another way to get the keys ?
or was it just for c.o.f.f.e.e ?
b) is it correct how it tried to animate the object ?
why is mix always 0 ?
or is there a better way to get the animated stuff from the object... ?
of course i would like to export keys... but if this don't work i would use animateobject... however just want to get it to run somehow
thanks in advance... ops got a bit long the post...sorry
ultra
