On 17/01/2006 at 05:02, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.52 Platform: Language(s) : C.O.F.F.E.E ; XPRESSO ;
--------- Hello to all !!
Can i make color correction on final render with Coffee or XPresso??
Tnx in advance for the answer !
On 22/01/2006 at 23:37, xxxxxxxx wrote:
Hello ...
I think VideoPostData plugin type may fill that requiremnt ... You can find VPInvertImage.cpp in the cinema4dsdk sample project ... That plugin change the final result of the render to a negative image ...
Wishing you all the best ... ZawMinTun
On 25/01/2006 at 04:28, xxxxxxxx wrote:
VideoPostData is the way to go, though that is C++. There's no way to do it using C.O.F.F.E.E. or Xpresso.
On 30/01/2006 at 03:31, xxxxxxxx wrote:
Wouldn't it be possible to modify images with COFFEE if you load them as a basebitmap? Of course the filter would not be executed automatically after the render, but you could load the rendered image manually and then execute the filter?
/Filip
On 01/02/2006 at 00:52, xxxxxxxx wrote:
Might be possible, but I'm confident that then People would prefer to use Bodypaint or Photoshop for that....
Kabe
