On 16/01/2006 at 03:55, xxxxxxxx wrote:
--------- Hello When I use : var result=filename->FileSelect(savetitle, TRUE); I want to set my own path in that folder the filesearch should start. How can I do it ? My try is this: RecFile = new (BaseFile); var filename = GeGetRootFilename(); //pfad holen filename->RemoveLast(); filename->AddLast("AutoRigs"); filename->AddLast("*.cxt"); // dateinamen zum pfad hinzufügen var savetitle=GetRes(SAVETITLE); var result=filename->FileSelect(savetitle, TRUE); But the Filesearch start in another Path then I want. The Filetype (*.cxt) is in the FileSelect Window. Thats ok, but the folder to start is another
On 16/01/2006 at 05:44, xxxxxxxx wrote:
Perhaps there's a typo somewhere in the path, so that the folder doesn't exist? Have you checked with the GetFullString() function, or whatever it's called, that the path is correct?
On 16/01/2006 at 16:12, xxxxxxxx wrote:
Ahrg, Yes ! Right - Thanks !!! Wrong Foldername Sorry...
