On 16/01/2006 at 03:11, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.52 Platform: Windows ; Language(s) : C++ ;
--------- Hi, I create some dynamic sliders in the attribute manager, I want remove some of them using the "remove entry" in the right clicking floating menu. I have set this parameter: Morph_Slider.SetBool(DESC_REMOVEABLE, TRUE); But the entry is still grayed. Any idea? Thank you. B->
On 26/01/2006 at 11:59, xxxxxxxx wrote:
I can't duplicate this. Try setting DESC_REMOVEABLE to TRUE in line 187 of morphmixer.cpp. Then the entry becomes enabled for me. Note that you will then get a MSG_DESCRIPTION_REMOVE_ENTRY message only. Nothing will be removed unless you do it yourself afaics.
On 27/01/2006 at 00:51, xxxxxxxx wrote:
Thank you, After looking at my code, I found the mistake: I was changing the parameters of the Slider: Morph_Slider.SetBool(DESC_REMOVEABLE, TRUE); But that was the Checkbox parameters that I had to change. Morph_Select.SetBool(DESC_REMOVEABLE, TRUE); Another question: I have to save a custom array in the C4D scene. Is it possible and Is it true that I have to use the CustomDataType class? Thank you B->
