Cannot set texture projection
    On 14/01/2006 at 14:05, xxxxxxxx wrote:
    Cinema 4D Version:   9.5
    Platform:      Mac OSX  ;
    I want to set the texture projection of a texture tag to UVW-mapping with C.O.F.F.E.E:
    var texTag = AllocTag(Ttexture);
    var con = texTag->GetContainer();
    println(con->GetData(TEXTURETAG_PROJECTION)); // Prints 0 = Spherical
    con->SetData(TEXTURETAG_PROJECTION, 6);
    println(con->GetData(TEXTURETAG_PROJECTION)); //Prints 6 = Should be UVW
    obj->InsertTag(texTag);
    Although the second println-command verifies in the console window that the TEXTURETAG_PROJECTION-value is set to 6, the projection-setting does not change neither in the perspective view nor the projection-dropdown-box in the attribute manager.
    What do i do wrong?
    On 26/01/2006 at 12:05, xxxxxxxx wrote:
    You're missing the command texTag->SetContainer(con); before the last line. Otherwise no data is set!
