On 21/11/2005 at 15:51, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.5 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- I am having a problem with GetFirstMaterial with 9.5. I broke my code down to the simplest form:
BaseDocument* doc = LoadDocument(fn,FALSE,NULL); if (!doc) return FALSE; BaseMaterial* mat = doc->GetFirstMaterial();
and mat is always NULL. The debugger reports the value for mat\BaseList2D "CXX0030: Error: expression cannot be evaluated"
fn is a valid filename and does contain materials.
I am using vc6.
Is this a problem with 9.5 or am I missing a step or something?
-Chris
On 22/11/2005 at 02:14, xxxxxxxx wrote:
Similar "LoadFile" but this time the document isn't put into the editors list of documents and you have control over the document_<_h5_>_> _<_h5_>_eturn > BaseDocument* > >> Document that was loaded, or NULL if it failed. > > <_<_h5_>_CKQUOTE> > > ##### _<_h5_>_rameters_ > >> const Filename & name >> >>> File to load the document from. >> >> LONG loadflags >> >>> Flags for the loader: > >>> >>>> Constant | Description >>>> ---|--- >>>> >>>>
\>>>> \>>>> \>>>> SCENEFILTER_OBJECTS \>>>> \>>>>
>>>> >>>> | >>>> >>>> Load/save only the objects and associated items, such as materials used. >>>> >>>>
\>>>> \>>>> \>>>> SCENEFILTER_MATERIALS \>>>> \>>>>
>>>> >>>> | >>>> >>>> Load/save only the materials. >>>> >>>>
\>>>> \>>>> \>>>> SCENEFILTER_DIALOGSALLOWED \>>>> \>>>>
>>>> >>>> | >>>> >>>> Flag to inform your plugin that a dialog can be displayed if you wish, if this flag not set then no dialogs must be opened. >>>> >>>>
\>>>> \>>>> \>>>> SCENEFILTER_PROGRESSALLOWED \>>>> \>>>>
>>>> >>>> | >>>> >>>> Flag to inform your plugin that a progress bar can be displayed if you wish. The progress bar can be set by calling StatusSetBar. >>>> >>>>
\>>>> \>>>> \>>>> SCENEFILTER_MERGESCENE \>>>> \>>>>
>>>> >>>> | >>>> >>>> Flag to inform your plugin that this is a merge operation, i.e. that the document you're inserting to is an existing scene. >>> >>> > >> >> BaseThread* thread >> >>> The current thread, or NULL for the main CINEMA 4D thread. The caller owns the pointed object. >>> >>> I think that u miss or put correctly flags & threads. >>> >>> Bye
On 22/11/2005 at 02:40, xxxxxxxx wrote:
Unlike older versions without this argument, the loadflags look to be necessary. Have you tried SCENEFILTER_OBJECTS or SCENEFILTER_MATERIALS for the loadflags argument?
As I'm supporting older versions with older SDKs, I hadn't noticed this change (new to R9.5 for sure!).
On 22/11/2005 at 05:46, xxxxxxxx wrote:
LOL I can't tell you how many times I looked over LoadDocument in the 9.5 sdk docs and never realized that "Bool show_error" had been replaced with "LONG loadflags".
Thanks guys. It's working now.
