Undo crash
On 25/10/2005 at 15:31, xxxxxxxx wrote:
Cinema 4D Version: 9.1
Platform: Windows ;
I tried using the following code to support Undo actions:StopAllThreads();
if(!doc->StartUndo())
GePrint("StartUndo() failed!");
if(!doc->AddUndo(UNDO_CHANGE,op)) GePrint("AddUndo(UNDO_CHANGE,op) failed!");//actually set new coords
p[frontpoint] -= result ^ axisstate;if(!doc->EndUndo())
GePrint("EndUndo() failed!");Where p is the PointObject pointer of op, which is the currently selected object. Only one point in the object gets moved.
When I try to undo it seems to work, but trying a second undo or a redo, cinema will die with an unhandled exception.
Any suggestions? Am I AddUndoing the wrong object?
Regards,
Zaphod
On 01/11/2005 at 07:35, xxxxxxxx wrote:
I don't know what could be wrong. I couldn't get the code you posted to crash. But it will be better with some code to update the editor:
PolygonObject* op = static_cast<PolygonObject*>(doc->GetFirstObject()); Vector* p = op->GetPoint(); StopAllThreads(); if(!doc->StartUndo()) GePrint("StartUndo() failed!"); if(!doc->AddUndo(UNDO_CHANGE,op)) GePrint("AddUndo(UNDO_CHANGE,op) failed!"); //actually set new coords p[0] -= Vector(100.0); op->Message(MSG_UPDATE); if(!doc->EndUndo()) GePrint("EndUndo() failed!"); EventAdd();
On 01/11/2005 at 08:54, xxxxxxxx wrote:
Thanks for your reply! I just fixed another bug of my plugin: http://www.plugincafe.com/forum/display_topic_threads.asp?ForumID=4&TopicID;=2077&PagePosition;=1
Seems I've now fixed two bugs with this one line of code ;-)
