Bump Strength
On 23/09/2005 at 11:55, xxxxxxxx wrote:
Cinema 4D Version: 9.5
Platform: Windows ;
Language(s) : C.O.F.F.E.E ;---------
Hi, does anybody know how to use the Bump Strength in C4D 9.5Her is part of my code that doesn't work
mat->SetChannelState(CHANNEL_BUMP, TRUE);
var Bmp = mat->GetChannel(CHANNEL_BUMP);
var BmpBc = Bmp->GetContainer();
BmpBc->SetData(CH_TEXTURE, BumpMap);
BmpBc->SetData(CH_BRIGHTNESS, 0.12); ---> Always 20% Bug???
Bmp->SetContainer(BmpBc);
Thank you.
On 23/09/2005 at 14:18, xxxxxxxx wrote:
It's not CH_BRIGHTNESS, it's BUMP_STRENGTH - go figure. ;)
On 24/09/2005 at 00:22, xxxxxxxx wrote:
I know, I've already tried:
The value of BmpInt is 1.0
I supposed the result would be 100% but it's always 20%
BmpBc->SetData(BUMP_STRENGTH, BmpInt); ---> Always 20% Bug???
Any Idea???
On 24/09/2005 at 08:54, xxxxxxxx wrote:
According to the COFFEE 9.1 docs, you can't get there from there. ;)
Container ID Type Explanation ------------------------------ CH_COLOR [vector] Color vector CH_BRIGHTNESS [float] Brightness CH_TEXTURE [string] Texture name CH_BLUR_OFFSET [float] Blur offset CH_BLUR_STRENGTH [float] Blur strength CH_INTERPOLATION [int] Interpolation (see dialog) CH_MIXMODE [int] Mix mode (see dialog) CH_MIXSTRENGTH [float] Mix strength CH_TIME_FROM [int] Movie from CH_TIME_TO [int] Movie to CH_TIME_FPS [int] Movie framerate CH_TIME_MODE [int] Sequence mode (see dialog) CH_TIME_TIMING [int] Sequence timing (see dialog) CH_TIME_START [BaseTime] Sequence start CH_TIME_END [BaseTime] Sequence end CH_TIME_LOOPS [int] Sequence loops
The Container only works with these settings common to channels.
With the C++ SDK, one would use SetParameter(), but this isn't available in the COFFEE SDK. Have you tried this instead:
BmpBc- >SetFloat(BUMP_STRENGTH,BmpInt);
On 24/09/2005 at 09:01, xxxxxxxx wrote:
Hi again,
I found that the container was not the good one!!!
Finally, this work:
var BmpIt = mat->GetContainer();
BmpIt->SetData(MATERIAL_BUMP_STRENGTH, BmpInt);
mat->SetContainer(BmpIt);
Thank you.
B->
