On 09/09/2005 at 06:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- I need to know how i can fill a coffeeexpression Tag with some source code(also COFFEE) via a plugin.
var coffeeTag=AllocTag(Tcoffeeexpression); //here i have to fill the tag with data!? myObject->InsertTag(coffeeTag);
How does it work?
On 11/09/2005 at 10:05, xxxxxxxx wrote:
i have the same question but the AllocTag always makes an ERROR when compiling. it syas varibale or function expected, instead of this Tcoffeeexpression... maybe we must enter a number?
On 12/09/2005 at 01:04, xxxxxxxx wrote:
the code:
var coffeeTag=AllocTag(Tcoffeeexpression); myObject->InsertTag(coffeeTag);
works fine. But i can't fill the tag with some source code. Whatfor do we need a number?
On 06/10/2005 at 08:19, xxxxxxxx wrote:
I#m new with Coffee. But what is happen when you user Number: 5675 ? var coffeetag=Alloctag(5675); myObject->Inserttag(coffeetag); I'm looking for a chance to make a coffee-Tag with Code, too! Expresso-Tag can be create, but can't filled with Nodes and connections Maybe Coffe is a way! Anybody knows how fill a coffe-Tag with code?
On 07/10/2005 at 07:22, xxxxxxxx wrote:
No Idea ?
On 07/10/2005 at 12:45, xxxxxxxx wrote:
Maybe I found a hint for that: C:\Programme\MAXON\CINEMA 4D R9\resource\coffeesymbols.h
I think that all constant of Coffee. There are: COFFEEEXPRESSIONTAG_PASS=1500, COFFEEEXPRESSIONTAG_TEXT=1000, Is Text maybe for Coffee-Code ? How can I put it in a Tag? With GetContainer and SetContainer ?
On 08/10/2005 at 04:34, xxxxxxxx wrote:
Is is Possible with that: var Tag = AllocTag(5675); if (!Tag) { println("could not allocate new MOCCA IK tag"); return; } var ccode = Tag->GetContainer(); ccode->SetData(COFFEEEXPRESSIONTAG_TEXT,"Hello"); Tag->SetContainer(ccode); if (!object->InsertTag(Tag)) { println("could not add MOCCA IK tag to current object"); return;
On 09/10/2005 at 17:15, xxxxxxxx wrote:
I'm not sure if I'm understanding the question, but if you are just looking for a way to create a plugin tag, the following page and its links helped me immensely:
http://www.geocities.com/eago9/coffeetuts/index.html
I hope this helps.
Aaron
On 10/10/2005 at 15:35, xxxxxxxx wrote:
I have find a Way. And publish it here: http://www.total3d.de/index.php?b=mmdocu&wo=viewkapitel&bo=10&ka=82#titel
