On 06/09/2005 at 02:00, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9 Platform: Windows ; Language(s) : C++ ;
--------- Hello ...
I want to know how can I know if the user is pressing Shift or Cntrl or Alt .. while using his mouse ... I'm using a Tool plugin ..
I tried these code below ...
LONG Key = msg.GetData(BFM_INPUT_CHANNEL).GetLong(); LONG ExKey=msg.GetLong(BFM_INPUT_QUALIFIER);
if(ExKey==QSHIFT) { MessageDialog("Shift is pressed"); }
MessageDialog(LongToString(Key));
But the dialog "Shift is pressed" is shown only when I press Shift and the other key like 'A' or 'B' ... So if I pressed only Shift key ( or Ctrl or Alt ) ... can I know it ... in anyway ...
Thanks in advance ... ZawMinTun
On 06/09/2005 at 10:52, xxxxxxxx wrote:
try this:
BaseContainer state; LONG keyState; if (GetInputState(BFM_INPUT_MOUSE, BFM_INPUT_MOUSELEFT, state)) { keyState = state.GetLong(BFM_INPUT_QUALIFIER); if (keyState == QSHIFT) { ... } }
On 06/09/2005 at 12:55, xxxxxxxx wrote:
Hi
the qualifiers are combined bitwise. So you can check each one by
if( key&QSHIFT; ) { // shift down } if( key&CTRL; ) { // ctrl down } .. ..
On 08/09/2005 at 21:09, xxxxxxxx wrote:
True ... So now I can solve my problem ... Really thank both of you ...
Let's meet again ... With all my respects ... ZawMinTun
