On 06/09/2005 at 01:35, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.1 Platform: Windows ; Language(s) : C++ ;
--------- I just updated my AMD64 system to Windows XP Pro x64, installed Cinema 4D R9.1 64-bit edition, and Microsoft Visual Studio 2005 beta.
Reading through your 'migration documentation', I see that you should, as expected, select an 'x64' target under new Platform Solution in Configuration Manager. But there is only "Pocket PC (ArmV4)" and "Smartphone (ArmV4)". I did a default install of VS2005.
I do notice that the version of Visual Studio is "Team Suite". Did I get screwed and receive the incorrect version or is this it? How do I get to an x64 target when there are none from which to choose?
Microsoft had better have some info on this - what's the use of all of the time just spent updating (many, many, many hours) to migrate to 64-bits if the end result is no 64-bit targets?
Peeved as hell, Robert
On 06/09/2005 at 01:47, xxxxxxxx wrote:
As far as I remember the 64 bit target is not enabled by default in the installer.
On 06/09/2005 at 01:52, xxxxxxxx wrote:
Yes, I just checked and saw that. "Welcome" to Micro.... (fill in the blank). They can't autodetect 64-bit hardware and their own friggin' OS and install the x64 compiler by default - or at least ask you?
So, for all future generations:
Don't use the default installer as it doesn't install anything you actually need. Now I remember why I spend 15 minutes customizing Office Pro installation settings - because their defaults, well, suck.
Thanks and long live any other OS.
