On 04/09/2005 at 13:00, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Windows ; Language(s) : C++ ;
--------- Hi,
anybody used the 'CommandNotify' func? can't find anything about it.
Just want a notification if a c4D file is loaded (new doc) I'm working in a commandplug, in a dialog
regards,
On 06/09/2005 at 12:50, xxxxxxxx wrote:
Now i see that its only called when something in the dialog onwn menu happens. I need to be called when main C4D is going to load and or save's a doc. Who know's how to do that ?
On 08/09/2005 at 01:20, xxxxxxxx wrote:
Ok,
I'm in a commandata plugin, or in a tagdata plug. How do i know if the document is going to be saved ?
In a tag i can use Read(), but: this is going to be called for every tag. I want only one call to initialize some data. I could use an incrementing global counter and take action when its zero, but, that's not very elegant.
Then: how do i know it in my commanddata plug ? Is there a message or a call i overlooked ?
kind regards,
On 13/09/2005 at 08:35, xxxxxxxx wrote:
bump
On 14/09/2005 at 13:17, xxxxxxxx wrote:
Listen for the document info message:
virtual Bool Message(GeListNode* node, LONG type, void* data) { if (type == MSG_DOCUMENTINFO) { DocumentInfoData* info = static_cast<DocumentInfoData*>(data); if (info && info->type == MSG_DOCUMENTINFO_TYPE_SAVE_BEFORE) { GePrint("Document is about to be saved!"); } } return TagData::Message(node, type, data); }
On 15/09/2005 at 15:04, xxxxxxxx wrote:
Ok, thanks Mikael.
But as i said: in a tag i can use Read() But that is going to be called for every tag. I want only one call. I use a master commanddata plug for management.
How can i catch this 'document info message' now, here is no type member.
Regards,
On 14/10/2005 at 03:53, xxxxxxxx wrote:
You can create a SceneHookData plugin to catch this in NodeData::Message().
