On 30/08/2005 at 07:47, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.102 Platform: Windows ; Language(s) : C++ ;
--------- I want to change the name of a button in my plugins GUI. I tried:
SetString(IDC_BUTTON, "New Text");
Nothing happens. Do I need to add an Event or is that late change simply not possible?
On 30/08/2005 at 23:38, xxxxxxxx wrote:
You can change it ... But as you said ... in an event that you wish ...
Let's say .. there is a code in CreateLayout function ...
//In CreateLayout AddButton(BTN_RENAME,0,100,10,"Rename");
And then in Command function ...
//In Command switch(id) { case BTN_RENAME: { SetString(BTN_RENAME,"NewName"); } break; }
If nothing happens ... please make it sure you didn't use the id of the button to other controls .. Sometimes it may happen like below ..
#define BTN_RENAME 1111
AddStaticText(1111,.... AddButton(BTN_RENAME,....
Hope it can help you ... ZawMinTun
On 31/08/2005 at 00:50, xxxxxxxx wrote:
Thanks for the help, but I already did it this way, except, that the button isn't added at runtime, but generated with the Resource-Editor, as recommended by the API doc.
Changing another static text (also pre- defined) works.
On 01/09/2005 at 10:25, xxxxxxxx wrote:
This was my fault, one shouldn't use an ID (IDC_NAME) for a button and a group-id. An ID should be unique in the *.res file.
Ok, this was trivial, but just in case someone finds my question after biting in the carpet with a similiar problem...
