On 13/08/2005 at 19:39, xxxxxxxx wrote:
User Information: Cinema 4D Version: R9 64Bit Platform: Windows ; Language(s) : C++ ;
--------- Hello all,
do i need activation code to enable the developing on C4D 64?
the error when i try to compile with Visual C++ 2005 is that some file to include are missing. These files are renamed in: _bplayer.h.off instead bplayer.h.
I see also a in plugin menu "activate module".
Thanks Renato T.
On 06/09/2005 at 04:52, xxxxxxxx wrote:
Renato, I hope that you've received your activation code by now.
You need to enter your regular R9 serial and then "activate module" with the activation code. Then you can activate all your purchased modules with their R9 serials.
