ListView
On 04/08/2005 at 21:39, xxxxxxxx wrote:
Cinema 4D Version: 9
Platform: Windows ;
Hello ...Have you ever used a listview without using the resource file ...
If so ... please take a look at my code ... It's not working the way I hope ... I took the ListView.cpp of Cinema4D as an example and coded(copied) like that ...SimpleListView listview1;
BaseContainer layout;
BaseContainer data;layout.SetLong('name',LV_COLUMN_TEXT);
listview1.SetLayout(1,layout);
for(i=0;i<5;i++)
data.SetString('name',"AAA"+LongToString(i));
listview1.SetItem(10+i,data);
listview1.DataChanged();
AddListView(1212,0,100,30);
listview1.AttachListView(this,1212);Nothing is shown in the dialog ... only the border ...
What's still needed to do that ...With all my respects ...
ZawMinTun
On 04/08/2005 at 21:46, xxxxxxxx wrote:
A sparse example of my code, you can see that the ListView must be added and attached to the Dialog before setting it up further. CreateLayout() is called before InitValues() whenever the dialog is opened.
CreateLayout() { ... AddListView(IP_SET_RUNTIMELIST, BFH_SCALEFIT|BFV_SCALEFIT, 0, 128); runtimeListView.AttachListView(this, IP_SET_RUNTIMELIST); ... } InitValues() { ... BaseContainer layout; layout.SetLong('chck',LV_COLUMN_CHECKBOX); layout.SetLong('name',LV_COLUMN_TEXT); runtimeListView.SetLayout(2, layout); // *** Add your list items here *** // Update RuntimeList after Settings loaded runtimeListView.DataChanged(); ... }
On 05/08/2005 at 00:37, xxxxxxxx wrote:
Right!!!!!!!!!!!!!
Thanks a lot ...
Now it works ...May the good lord bless you always ...
With all my best wishes ...
ZawMinTun
