On 18/07/2005 at 02:31, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9 Platform: Windows ; Language(s) : C++ ;
--------- Hello ...
Now I'm facing a problem ... Hope you'll help me as in old times ...
I tried to create some object plugins ... Then I had to pass a tif file (or) two tif files for registering when I use the RegisterObjectPlugin ... I think I heard they say the pic is needed to be 32X32 ... So I follow that rule ...
But for some tif files .... there is a problem and as the result they didn't come to the menu list ... Some tifs works well ...
But I hope you understand my problem ... I use A.tif for plugin A ... But now in this debugging time I have to use B.tig for plugin A ...
So what do I need to do?
With all my respects ... ZawMinTun
On 18/07/2005 at 05:28, xxxxxxxx wrote:
only uncompressed tiffs are working. Nothing else needs to be worried about for tiffs.
On 20/07/2005 at 20:06, xxxxxxxx wrote:
Thank you Katachi ... very much ... I use Photoshop and compress it to reduce the size ... It's the reason for not working properly ... Now I set compression to None and it's working ...
Let's meet in my next problem ...
With all my best wishes ... ZawMinTun
