On 30/05/2005 at 21:55, xxxxxxxx wrote:
User Information: Cinema 4D Version: Platform: Windows ; Language(s) :
--------- Hi, i have 1 question about inline assembly. as shown in the program listing below, if i remove "asm cli", "i=8, flag=5" statement will not be executed.....why the program doesn't work??? why inline assembly asm makes the difference? I'm hoping that i can get the answer here. please and thanks. #include <mc9s12dp256.h> /* derivative information */ #include "pll.h" /* defines _BUSCLOCK, sets bus frequency to _BUSCLOCK MHz */
void main(void) { unsigned int i, flag; /* set system clock frequency to _BUSCLOCK MHz (24 or 4) */ PLL_Init(); /* set port B as output (LEDs) */ DDRB = 0xff; // Port B is output /* allow all interrupts */ asm cli //weirdness happen here i = 8; if (i==8) { flag=5; } /* forever */ for(;;){} // remove this to make things even worse... }
On 30/05/2005 at 23:21, xxxxxxxx wrote:
Hi, this is a MAXON Cinema 4D plugin development forum, not a general-purpose C/C++/ASM forum. Unless this problem is related to a Cinema 4D C++ SDK plugin, you would do better on a general computer development/programming forum.
Additionally, you don't give the system (MacOS, Linux, Unix, Windows, DOS), compiler (CodeWarrior, MSC++, Borland, DJGPP etc.), or any other information that would help to narrow the problem. To which compiler is "asm cli" specific, for instance?
Thanks,
