On 30/05/2005 at 14:40, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.2 Platform: Windows ; Language(s) : C++ ;
--------- Hi, Does anybody know how a xpresso node with more then one output, can be updated (calculated) in one go. (set all outputs at the same time). Think I have my plug somewhat going now. (I hope) Maybe someone with experience could have a look ? http://www.frieslandav.com/camgriptools.php (for windows) With regards,
On 01/06/2005 at 10:58, xxxxxxxx wrote:
Internally I guess you could do the calculations at the first request for either of the ports, but the basic philosophy is that outputs are calculated when they are needed for other inputs. The "Graph view calculation" page of the docs has a better explanation, if you haven't already read it.
On 01/06/2005 at 12:39, xxxxxxxx wrote:
Yes I have read the article. It is most likely done to prevent overhead calculation. but my cycle is: sample data in struct; output to ports.
Well I have to find another way. Thanks Mikael. http://www.frieslandav.com/camgriptools.php (for windows) with regards,
