On 21/05/2005 at 12:44, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.1 Platform: Windows ; Language(s) : C.O.F.F.E.E ; XPRESSO ;
--------- Hello, I'm just starting to try and learn coffee and would like to start out by making some simple functions. First I would like to make a coffee expression where I could have one bone aim at another bone. (pretty simple) I could use some tips/advice as to where to start and how to go about getting that done. If there any examples around that would help too. Thanks Dave
On 22/05/2005 at 20:00, xxxxxxxx wrote:
Oh and I would also like the bone to scale to the target bone so that you get a muscle type of bone. An aim at with scale if you get what I mean.
On 23/05/2005 at 20:43, xxxxxxxx wrote:
Ok I have used the code from the target node that comes with C4D to work on this problem. It does all the aim at stuff already. I have added a var to get the distance between the target bone and the object bone. Now I'm stuck on how to adjust the object bones length to the distance var I have added. How do I go about setting the bones length to the var (dist) I have? Here is the code with my line added in: main() { var mobj = Muscle->GetMg(); var tobj = Target->GetMg(); var p1 = mobj->GetV0(); var p2 = tobj->GetV0(); var dist = p2 - p1; //gets distance from p1 to p2 var m = new(Matrix); m->SetV0(p1); m->SetV3(vnorm(p2 - p1)); m->SetV2(vnorm(vcross(p2-p1, vector(0,1,0)))); m->SetV1(vnorm(vcross(p2-p1, vector(0,0,1)))); Rotation=m->GetHPB(); var orot=mobj->GetHPB(); Rotation.z=orot.z; }
On 01/06/2005 at 12:17, xxxxxxxx wrote:
If you drag the Length field of a bone and drop it in the C.O.F.F.E.E. editor window, you'll see that it writes "#BONEOBJECT_LENGTH". This means that you can set the length with
op#BONEOBJECT_LENGTH = dist;
where 'op' is the bone object.
