Load a C4D file in XML format.
    On 18/05/2005 at 10:56, xxxxxxxx wrote:
    Cinema 4D Version:   9
    Platform:   Windows  ;
    I want to write a Command Plugin. All it does when executed is loading a c4d file in XML format from C:\file.xml
    I know this seems not to make much sense as the user can manually open it using File>Open, or simply by double-clicking the file. Well, it would be too hard to explain what I have in mind - please just answer the question I asked.
    What is the quickest way to do this using the C++ SDK.
    On 18/05/2005 at 11:07, xxxxxxxx wrote:
    LoadDocument() or LoadFile().
