On 16/05/2005 at 11:08, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- hi. im a total coffee beginner. and i could use some help. i hope you can help me.
the following script does not work. because ist wrong, but i dont know how to do i better. please help.
include "c4d_symbols.h" var PLUGIN_ID = 1017883; //TerraCOFFEE id from www.plugincafe.com var PLUGIN_NAME = "tc"; var HELP_STR = "tc"; var d; var resource; class TerraCOFFEE : MenuPlugin { public: TerraCOFFEE(); GetID(); GetName(); GetHelp(); Execute(doc); RestoreLayout(secret); } //*---------------Dialog--------------* class TCDialog : GeDialog { public: TCDialog(); CreateLayout(); Command(id,msg); Init(); } //*--------------Resource-------------* class TCResource : GeResource { public: TCResource(path); GetString(id); } //*---------------Funktionen----------* TCResource::TCResource(path) { super(path); } GetString(id) { } TCDialog::TCDialog() { super(PLUGIN_ID); } TCDialog::Init() { } TCDialog::CreateLayout() { return LoadDialogResource(TC_DIALOG, resource, 0); } TerraCOFFEE::TerraCOFFEE() { super(); } TerraCOFFEE::GetID() { return PLUGIN_ID; } TerraCOFFEE::GetHelp() { return HELP_STR; } TerraCOFFEE::GetName() { return PLUGIN_NAME; } TerraCOFFEE::Execute(doc) { if (!d) d = new(TCDialog); d->Open(TRUE,-1,-1); } TerraCOFFEE::RestoreLayout(secret) { if (!d) d = new(TCDialog); d->RestoreLayout(secret); } main() { var root = GeGetRootFilename(); root->RemoveLast(); var resource = new(TCResource, root); Register(TerraCOFFEE); println("loaded"); }
i'm desperate....
On 17/05/2005 at 16:30, xxxxxxxx wrote:
i think i should formulate taht one better:
how do i use the GeResource with an non-modal dialog in the right way?
