Shader drived from a Tag
On 11/05/2005 at 08:55, xxxxxxxx wrote:
Cinema 4D Version:   8.2+
Hi all,
I need to write a shader drived by a my PluginTag.
Maybe like a Proxymal Shader.
Can someone help me to understand how i can pass parameter from a TAG to a shader?
I thought to an array that contain a index for all objects that have same texture tag... but how?
thanks all
Renato T.
On 11/05/2005 at 10:27, xxxxxxxx wrote:
If no one has a better idea, you could always use messaging. I've used MSG_RETRIEVEPRIVATEDATA to pass structs and arrays (in the void* data of a RetrievePrivateData struct) to and from my own plugins with much success.
Basically, when your shader needs information from these tags, the shader can send a message like this with a RetrievePrivateData struct, the tag fills the data (and maybe sets the flags), and the shader retrieves what is filled into it.
If you need to look for tags, I suggest getting the BaseDocument from the node (node->GetDocument()), and then set up a recursive method in the shader to get each object and check for tags:
// These will need to be defined accessible for MyShader and MyTag
#define RPDATA_SET     0
#define RPDATA_GET     1
struct MyDataStruct
     // whatever data is to be passed
Bool MyShader::SomeMethod()
     BaseDocument* baseDoc = node->GetDocument();
     if (!QueryTag(baseDoc, baseDoc->GetFirstObject()) return FALSE;
     return TRUE;
// Recursively check Document Object's for your PluginTag
Bool MyShader::QueryTag(BaseDocument* baseDoc, BaseObject* obj)
     LONG nr;
     PluginTag* pt;
     RetrievePrivateData rpdata;
     MyDataStruct myDataStruct;
     for (obj; obj; obj = obj->GetNext())
          /* Do this here to perform leaf->root traversal
          // Handle children
          if (!QueryTag(baseDoc, obj->GetDown())) return FALSE;
          // Get each MyPlugin tag from object (if nay)
          for (nr = 0; pt = (PluginTag* )obj->GetTag(ID_MYTAG, nr); nr++)
               // Messaging
               rpdata.flags = RPDATA_GET;
               rpdata.data = &myDataStruct;
               if (pt->Message(MSG_RETRIEVEPRIVATEDATA, &rpdata;))
                    // extract data filled by your PluginTag
          // Do this here to perform root->leaf traversal
          // Handle children
     return TRUE;
On 11/05/2005 at 10:51, xxxxxxxx wrote:
Thanks Robert,
i'll analize your code, i hope to get the right way from this.
Thanks
Renato T.
On 11/05/2005 at 15:31, xxxxxxxx wrote:
Now i need to know the Object ID from VolumeData.
I mean what RayObject is processing the shader.
Maybe easy but i don't find it.
Thanks
Renato T.
On 11/05/2005 at 17:13, xxxxxxxx wrote:
you can find the object in the volumedata
BaseObject* op = vd->op->link;
always check if NULL
hope this helps
Matthias
On 11/05/2005 at 17:22, xxxxxxxx wrote:
Argh.. i lost it in BaseVolumeData 😞
thanks Matthias
Renato T.
On 12/05/2005 at 10:12, xxxxxxxx wrote:
Matthias,
I've looked for a unique id for objects but i don't find it.
I have a tag (N.o.t.a.) that manage Global Matrix of all objects grouped.. so i don't have a tag for each object and i need to check for a "id" if exist so i can look on my tag (or if possible add in each object container) for some data for index that can drive my Shader.
I hope that you understand what i mean.
Renato T.
On 13/05/2005 at 00:15, xxxxxxxx wrote:
Nevermind 🙂
it's easy to add a data to container of all objects.. if is possible to do or add invisible tag for each object.
Thanks
Renato T.
On 13/05/2005 at 00:47, xxxxxxxx wrote:
you can get a unique id with GetUniqueIP()
//source of Output of your pluginshader
//cd is the ChannelData
BaseObject *op = NULL;
op = cd- >vd->op->link;
LONG id = 0;
if(op) id = op->GetUniqueIP();
best,
Matthias
