On 09/05/2005 at 06:30, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.1 Platform: Windows ; Language(s) : C++ ;
--------- Hello again,
in how far are those two different ?
UserArea and a Thread. The Thread ist continuously calculating stuff. And the UserArea must show this stuff. So in GeUserArea::Draw() i must synchronize with the thread and aquire data to be drawn.
Using a GE_SPINLOCK doesn't work. It looks as if the Draw functions get's mysteriously removed from the stack somewhere after calling GeSpinLock(), and so creating a deadlock because GeSpinUnlock get's never called.
Using a Semaphore does work flawlessly.
I was wondering why.
On 09/05/2005 at 06:47, xxxxxxxx wrote:
Forget it, it must be my fault. It works in a simple testprogram.
On 09/05/2005 at 09:15, xxxxxxxx wrote:
Ok i pinned it down to a call to GeDialog::SetTitle() in between GeSpinLock() and GeSpinUnlock()
maybe it's API bug.. if you change things in AsyncTest.cpp from the SDK Examples like this, then it will also freeze. And i see nothing that would be illegal.
//added class TestThread : public Thread { public: virtual void Main() { someData = 0; while( !TestBreak() ) { GeSleep( 400 ); LockData(); for( LONG i=0; i<1000; ++i ) { ++someData; } UnlockData(); } } void LockData() { GeSpinLock( &lock; ); }; void UnlockData() { GeSpinUnlock( &lock; ); }; ULONG* GetData() { return &someData; }; GeUserArea *ua; GE_SPINLOCK lock; private: ULONG someData; }; class SDKGradientArea : public GeUserArea { public: SDKGradientGadget ggtmp; SDKGradient grad[MAXGRADIENT]; LONG count,interpolation,type; // added TestThread thread; SDKGradientArea(void); virtual Bool Init(void); virtual Bool GetMinSize(LONG &w;,LONG &h;); virtual void Sized(LONG w,LONG h); virtual void Draw(LONG x1,LONG y1,LONG x2,LONG y2); virtual Bool InputEvent(const BaseContainer &msg;); }; Bool SDKGradientArea::Init(void) { ggtmp.Init(this,grad,&count;,&interpolation;,MAXGRADIENT); // added thread.ua = this; thread.lock = 0; thread.Start( TRUE, FALSE ); return TRUE; } void SDKGradientArea::Draw(LONG x1,LONG y1,LONG x2,LONG y2) { if (!ggtmp.col) return; LONG w = ggtmp.col->GetBw(); LONG h = ggtmp.col->GetBh(); // added thread.LockData(); ULONG *data = thread.GetData(); GeDebugOut("data = %i",*data); // this seems to cause a freeze dlg->SetTitle( LongToString( *data ) ); thread.UnlockData(); DrawBitmap(ggtmp.col,0,0,w,h,0,0,w,h,0); }
On 09/05/2005 at 12:14, xxxxxxxx wrote:
I already posted this where you initially asked it. It is not permitted to call gui functionality in a threaded context. So this might also cover setting the title of a dialog. This is at least what the SDK documentation says. So it seems illegal.
On 12/05/2005 at 03:12, xxxxxxxx wrote:
Hi
you know i have strong doubts that it is illegal because the Draw function seems to be executed in the main thread.
But i guess i will never know for sure...
