On 06/05/2005 at 05:09, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.5 Platform: Windows ; Language(s) : C++ ;
--------- Morning!
I'm currently testing a few shader ideas out using the TraceGeometry command in the VolumeData struct, but am having some weird results. When I transform the current ray for objects near the camera they seem skewed like the scene is being viewed thru a fish-eye lens! Is this a perspective effect, and has anyone experienced this at all?
Ta
Dan
On 09/05/2005 at 01:14, xxxxxxxx wrote:
no, haven´t experienced this yet.
On 10/05/2005 at 02:35, xxxxxxxx wrote:
Oh, ok. Might be something to do with the way I'm transforming the ray I guess?
On 10/05/2005 at 06:06, xxxxxxxx wrote:
Without some more information we'd all be guessing maybe you could post a code snip or at least what transform you are doing to the ray.
On 11/05/2005 at 07:40, xxxxxxxx wrote:
Hi David
I maybe be doing something really stupid when transforming the ray, perhaps my 3d maths need polishing up a bit! I'll probably need to go into some depth to explain what is going wrong, and you contactable? Or could you mail me please?
On 11/05/2005 at 07:49, xxxxxxxx wrote:
You would be better off posting here, this way someone with the right experience might know an answer plus it helps everyone else if they come across a similar problem.
On 11/05/2005 at 10:24, xxxxxxxx wrote:
Ok fair enough. Basically to summarise in a reasonable amount of code ...
The code below gets the current ray, transforms it to another objects inverted global matrix (got using ->GetMg), then checks whether the new ray intersects or not (so if hit, col=white, else col=black) - see below :
[CODE} Ray *ray, invray;
ray = vd->ray; Vector pos = SV(ray->p); Vector dir = SV(ray->v); Vector newpos = globalMat * pos; Vector newdir = globalMat * dir; invray.p = LV(newpos); invray.v = LV(newdir);
vd->TraceGeometry(&invray;, MAXREAL, 0, &p;, &n;, &hit;);
if(hit) vd->col = Vector(1.0, 1.0, 1.0); else vd->col = Vector(0.0, 0.0, 0.0);
... {/CODE]
Does this help explain whats going wrong at all?
Cheers ...
On 12/05/2005 at 08:37, xxxxxxxx wrote:
Hi
direction vectors are usually transformed by newdir = dir^globalMat; This omits the translation.
On 12/05/2005 at 09:15, xxxxxxxx wrote:
Cheers Michael, will give that a go ...
On 13/05/2005 at 01:30, xxxxxxxx wrote:
Wow! That worked like a treat. Still a little bit of weirdness going on in the distance, but probably my maths!!
Excellent Michael, thanks!
