On 03/05/2005 at 13:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: 7 Platform: Windows ; Language(s) : C++ ;
--------- Hi again At last I think I have found the problem to my TraceColor/TraceColorDirect problems. After an 'interesting' debugging session, I found that when the command is called it infinite recurses until the memory runs out and it has a 'stack overflow'. Now in the SDK docs it says : " Note: Always use a limit for the recursion (typically a value from 6 to 20) to avoid the danger of a stack overflow." So ... how on earth do I do this? Is there a variable I need to set, or is there something more clever I need to do? Please HELP!! Much Thanks Dan
On 13/05/2005 at 02:38, xxxxxxxx wrote:
For example if you call this function in CalcColor(), then you need to increment a variable somewhere in your plugin so that if the call to TraceColor() calls CalcColor() again you know how far the recursion has gone.
