On 03/05/2005 at 02:15, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.207 Platform: Windows ; Language(s) : C++ ;
--------- Is it ok if I use the stdlib when writing plugins? Well, I guess it is, asking just to be on the safe side....
On 03/05/2005 at 02:30, xxxxxxxx wrote:
Yes, most functions should be ok. Anything particular you had in mind? If you mean the C++ library you have to take care not to let any exceptions escape to C4D.
On 03/05/2005 at 02:40, xxxxxxxx wrote:
At the moment I think about list, vector, map..., in general all container classes, no i/o.
On 03/05/2005 at 02:45, xxxxxxxx wrote:
I have used those myself and they work fine. The only thing to keep in mind is that the STL library might use global variables. So if you get mysterious startup crashes you need to set the __WINCRTINIT flag. (Search the forum for more information on this flag.)
