On 30/04/2005 at 02:43, xxxxxxxx wrote:
User Information: Cinema 4D Version: R9 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- Hi All,
i'm playing with splines in DoubleCircle source that generate spline from child object. The problem is that don't refresh when i change childs objects. What's the correct method to refresh when i change somethings in childs splines?
Thanks all Renato T.
On 03/05/2005 at 02:19, xxxxxxxx wrote:
OBJECT_SPLINE doesn't support the generator concept and I believe this is one of the limitations. A workaround is to use OBJECT_GENERATOR and generate splines in GetVirtualObjects(). Such generator objects will work as splines in most other objects.
On 03/05/2005 at 06:26, xxxxxxxx wrote:
Thanks Mikael,
I'm working in these day with a Object Generator and i got no probs with it. I'll try with splines too
Cheers Renato T.
