On 24/03/2005 at 12:05, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.1 Platform: Windows ; Language(s) : C++ ;
--------- Hi, how can i add tabs to the attribute manager. i am using the tagdata plugin
On 24/03/2005 at 12:55, xxxxxxxx wrote:
tabs? The resouces have GROUP elements that automatically add quicktabs to the AM. You don´t have to code them yourself.
On 24/03/2005 at 14:11, xxxxxxxx wrote:
Can i use these with description res files too ?
On 24/03/2005 at 15:59, xxxxxxxx wrote:
yes, they are used in the description res files. Just have a look at other C++ plugins with description resources (.res files as you correctly stated). They have the
GROUP ID
flag, which will automatically add a new quicktab if you specify the ID part. means, you give it a "name" and then list this "name" in your description .h file (and in the .str file of course, so Cinema knows what string to show as tab name).
//In your .res file
GROUP MY_GROUP_NAME { //Add elements in here. Example: REAL ID_OF_ELEMENT {MIN 0;MAX 100; STEP 0.01;} }
//In your .h file (Example code)
enum { MY_GROUP_NAME = 1000, ELEMENT_IDs, [...]
_MY_DUMMY_ };
//In your .str file
MY_GROUP_NAME "Tab Name";
Hope that helps
On 25/03/2005 at 02:04, xxxxxxxx wrote:
Got it, it works... Ok, thanks so much...
