On 20/02/2005 at 17:43, xxxxxxxx wrote:
User Information: Cinema 4D Version: 6.3-9.0 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- I have a user rightfully complaining that he cannot use my "Drop It!" plugin with InstanceObjects. If the object is not a PointObject, I call MakeEditable(doc, object) so that the points can be used in the calculation. This doesn't work with InstanceObjects it appears.
Here is my function:
// Input: BaseDocument doc, BaseObject op FloorDialog::MakeEditable(doc, op) { var bc = new(BaseContainer); doc->AddUndo(UNDO_OBJECT_REC, op); SendModelingCommand(MCOMMAND_MAKEEDITABLE, doc, op, bc, MODIFY_ALL); }
Is there something different that needs to be done when using InstanceObjects (and what is it)?
Thanks,
On 20/02/2005 at 22:53, xxxxxxxx wrote:
Got it working. Just involved checking whether or not the made-editable InstanceObject itself needed to be made-editable.
