On 16/02/2005 at 02:44, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.1 Platform: Mac ; Language(s) : C.O.F.F.E.E ;
--------- Hello,
I have a scene with about 8000 Objects which should all rotate a bit different. I'm developing a Plugin that should set the rotation for all those objects. I tried to create a rotation Track using COFFE, but didn't succeed. I was able to create a track, with a sequence ("Winkel") and keyframes but the objects don't rotate. Didn't find out how to create Winkel.H, etc. sequences. In the new SDK I've read that COFFEE can't be used to create tracks, which I don't understand, as I was able to create these tracks. My next idea was to use a Vibration Tag, but I couldn't find any information in the reference which fields I have to set in the container.
Can anyone please tell me which would be the best way to let all these objects rotate?
Thank Mapache
On 16/02/2005 at 06:38, xxxxxxxx wrote:
Solved my Problem. Will use the VibrationTag now.
Found the Drag&Drop; Feature for the id (Drog and Drop an Element to the console to get the id).
