On 19/01/2005 at 07:55, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Mac ; Language(s) : C.O.F.F.E.E ;
--------- How can I turn off a primitive object off (green tick to red X) using COFFEE? Thank you in advance
Rui Batista
On 19/01/2005 at 10:33, xxxxxxxx wrote:
Ok, never mind... found it. But its not very obvious, from the documentation
On 21/01/2005 at 09:59, xxxxxxxx wrote:
If you told me how to do it, the next version of the C.O.F.F.E.E. docs might be a bit better. (And people searching the forum would also know how to do it.)
On 21/01/2005 at 11:32, xxxxxxxx wrote:
You are right, Mikael. Well, I searched and searched and I could only find:
GetEditorMode()
but that only gives me the semaphores.
Then, walking backwards, I found BaseList2D and the command SetBit. In it, there is this line:
BIT_AOBJ - Active object
But this is missleading because what it really means is that that object is SELECTED, not active or inactive.
Since this was not helping me, I wend back to BaseObject. And, incidently, I clicked in GetDeformMode. Well, I would never relate this with the green tick but I read there:
MODE_ON - Green tick (on) MODE_OFF - Red cross (off) NOTOK - Object has no tick
There was no SetDeformMode command but, since there was a GetDeformMode, for the sake of cumplementarity, I risked and typed:
op->SetDeformMode(MODE_OFF);
And it worked!!! But I didn't found it documented.
