On 10/01/2005 at 05:40, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.50 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hello, i want to make a function which sort my doc new. I have many Objects with the same Name. They should be Grouped under a NullObject. My Problem is that not all Objects were taken. My function dosen't take Objects which are deeper in the Hierachie and I don't know why. Can anyone please help me? Here is my function: FindAndMove(ObName,NObName,op,doc){ var ... parent = doc->FindObject(NObName); while(op){ nam=op->GetName(); if(nam=ObName){ op->Remove; op->InsertUnter(parent); b=tostring(i); b+=ObName; //Rename the object, so that it would not be found a 2.time op->SetName(b) op->Message(MSG_UPDATE); } if(op->GetDown){ FindAndMove(ObName,NObName,op,doc); } op=op->GetNext(); } }
Greetings Tim
On 14/01/2005 at 08:18, xxxxxxxx wrote:
If you're recursive function is too deep then there will be a stack error. You will have to turn one dimension of the recursion into a while-loop instead.
Recurse(op) { while (op) { DoSomething(op); Recurse(op); op = op->GetNext(); } }
On 17/01/2005 at 05:00, xxxxxxxx wrote:
Thanks, i got an stack error. your functions works great!
Greetings...
