On 04/01/2005 at 10:28, xxxxxxxx wrote:
User Information: Cinema 4D Version: 9.012 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- I've received a valid bug report for one of my COFFEE plugins that only occurs in R9.012 (no problems in earlier supported versions). Here is the code:
var oc, op; if (!(op = GetActiveObject(doc))) return; // Process active Object // - Make editable if necessary if (!instanceof(op, PointObject)) { var bc = new(BaseContainer); doc->StartUndo(); doc->AddUndo(UNDO_OBJECT_REC, op); SendModelingCommand(MCOMMAND_MAKEEDITABLE, doc, op, bc, MODIFY_ALL); doc->EndUndo(); op = GetActiveObject(doc); undos = TRUE; } // This line prints! if (!op) println("That ain't right!");
And, yes, there is an active object in the first call. This could be related to SendModelingCommand()?
Any work arounds for this - like an update to COFFEE, finally?
Thanks, Robert
On 04/01/2005 at 11:27, xxxxxxxx wrote:
Worked it out. Definitely a difference in SendModelingCommand() causing the issue. The workaround is not to try to do it to a Nullobject grouped set in R9. What did you guys do in R9?!
