On 07/12/2004 at 14:34, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.200 Platform: Mac OSX ; Language(s) : C.O.F.F.E.E ; C++ ;
--------- Hi,
In trying to learn the ropes of CPP object plugin development and I realize that I don't understand how to display the child objects of the plugin in GetVirtualObjects.
For now, as a simplification of what I am really trying to do, I am essentially trying to create an object plugin that would behave as a Null Object.
From the atom.cpp I am creating instances of the children and attaching them to the plugin object, which works, but when I just try to attach the child itself to the returnObject I get a crash. As I step through the children, how do I attach them to the returnObject in GetVirtualObjects? Or, in the code below, what do I add between the comments with question marks?
BaseObject *MyNullObject::GetVirtualObjects(PluginObject *pluginObject, HierarchyHelp *hh) { BaseObject* returnObject = NULL; BaseObject* orig; BaseObject* res; BaseObject *obi = NULL; Bool dirty; BaseContainer* data = pluginObject->GetDataInstance(); // request polygonized input hh->AddVFlags(VFLAG_POLYGONAL); orig = pluginObject->GetDown(); if (!orig) return NULL; dirty = FALSE; res = pluginObject->GetAndCheckHierarchyClone(hh,orig,HCLONE_ASPOLY,&dirty;,NULL,TRUE); if (!dirty) { return res; } if (!res) { return NULL; } returnObject = BaseObject::Alloc(Onull);; // STEP TRHOUGH EACH CHILD OF THE PLUGIN ONBJECT while (orig) { BaseContainer *origdata = orig->GetDataInstance(); // ??? WHAT SHOULD I DO HERE TO JUST DISPLAY/RETURN THE CHILDREN INSTEAD OF INSTANCING THEM? obi = BaseObject::Alloc(Oinstance); AutoAlloc<BaseLink> link; if (link) { link->SetLink(orig); obi->SetParameter(DescLevel(INSTANCEOBJECT_LINK), GeData(link), 0); } // ???? obi->InsertUnderLast(returnObject); orig = orig->GetNext(); } if (!returnObject) goto Error; returnObject->SetName(pluginObject->GetName()); return returnObject; Error: blDelete(returnObject); return NULL; }
On 08/12/2004 at 01:00, xxxxxxxx wrote:
You can't return the children themselves. That will cause a crash. You need to create clones of the children, just like the examples do.
On 08/12/2004 at 05:15, xxxxxxxx wrote:
Thanks Mikael - that worked like a charm. I have one more related question: Based on the Atom example, I was not only using instances but also GetAndCheckHeirarchyClone to test if the object was dirty. But in MophMixer, they use CheckCache. When would one use one over the other?
