Dragging from TreeView to LinkBoxGui
On 08/11/2004 at 07:50, xxxxxxxx wrote:
Cinema 4D Version: 8.100
Platform: Windows ;
i have in my Dialog a TreeView and a DescriptionCustomGUI. In some cases i need to drag an element (ObjectData) from the TreeView to a LinkBoxGui in the DescriptionCustomGUI.While dragging over the linkbox, the dragged element is shown in the linkbox (like accepting the object). But after releasing the mouse, the link box leaves empty.
I start the dragging in the TreeView in GenerateDragArray, where i add my object directly to the AtomArray.
The DescriptionCustomGUI was created with DESCRIPTION_OBJECTSNOTINDOC and the dragged object is not in a document. May this cause the problem?
How is the SetLink() for a LinkBoxGui done manually? Can i assign my object (ObjectData* myobjectdata) directly to the LinkBoxGui, like:
mybasecontainer->SetLink(LINKBOX_ID, myobjectdata);Torsten
On 10/11/2004 at 02:54, xxxxxxxx wrote:
Hmm, yes I guess this would be a problem. BaseLinks are made for objects that belong to a document. The criterion for having your link show up in the link GUI is that GetLink(GetActiveDocument()) doesn't return NULL.
On 10/11/2004 at 08:19, xxxxxxxx wrote:
OK, will it work if a create a BaseDocument with Alloc, insert my objects to this document, but will not insert the document to C4D?
If not, then i have to do my job with a kind of combobox. But i can't find any example, how to add items to an existing, empty CYCLE.
mycontainer.res:
LONG ACTIVEOBJECTINDEX
CYCLE
...How to add and remove items dynamically? And how to read the selected item?
Thank you for your help.Torsten
On 01/05/2005 at 04:27, xxxxxxxx wrote:
Hi All,
If i add to my description *.res file for the AM : (NOT in a dialog)
LINKBOX MY_ID { CUSTOMGUI_LINKBOX ; }
C4D comes with a "Error reading resource" message.
What is it that i do wrong?
Thanks
On 01/05/2005 at 08:25, xxxxxxxx wrote:
It's not LINKBOX, it's LINK - check the SDK documentation under "Description resource" for details. :)
On 01/05/2005 at 11:57, xxxxxxxx wrote:
Ah thank you robert, got it working.
