Member variables in ObjectData
On 27/10/2004 at 23:01, xxxxxxxx wrote:
Cinema 4D Version: 8.100
Platform: Windows ;
I have an object derived from ObjectData. I have one member variable in this object (e.g. String). But i can not save any data in this variable. Why?
class MyObjectData: public ObjectData
INSTANCEOF(MyObjectData,ObjectData)
public:
static NodeData *Alloc(void){return gNew MyObjectData;}
virtual Bool Init(GeListNode *node);
void ShowValue();
private:
String text;
Bool MyObjectData::Init(GeListNode *node)
text = "hello"; //assigning a value
return TRUE;
void MyObjectData::ShowValue()
GePrint("Text:" + text); //variable text is empty
Thanks,
Torsten
On 28/10/2004 at 08:59, xxxxxxxx wrote:
First, you could easily store the String in a BaseContainer with an id (i.e.: node->GetDataInstance()->SetStaticText(MYOBJECTDATA_TEXT, "hello")), but that's beside the point. :)
Everything looks proper. Init() is called directly after the constructor during gNew, so it should have a valid value afterwards. Have you tried GePrint() within Init()? Are you at least getting "Text:" to show in the console?
Robert
On 03/11/2004 at 11:09, xxxxxxxx wrote:
I can't see either why this wouldn't work in the code posted. Perhaps your object is cloned? You'd need to implement the CopyTo(), Read() and Write() functions to make the data persistent.
