On 15/09/2004 at 07:20, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.207 Platform: Windows ; Language(s) : C++ ;
--------- I want to make a customgui for LONG values, kind of progress bar I can just set by the LONG value. I sucessfully designed a customgui together with a custom data type before, but here I have problems. First of all: Is it possible to make a customgui without custom data type? The data would only be a LONG value, so it would be nice to use LONG. Take a look at this code ( just displaying a number for testing, only the cpp part ). My problem: iCustomGui::SetData is never called. class grProgressBarGui : public iCustomGui grProgressBarGui::grProgressBarGui( const BaseContainer &settings, CUSTOMGUIPLUGIN *plugin ) : iCustomGui( settings, plugin ) { } LONG grProgressBarGui::GetCustomGuiWidth( ){ return 100; } LONG grProgressBarGui::GetCustomGuiHeight( ) { return 100; } void grProgressBarGui::CustomGuiRedraw( ) {
} Bool grProgressBarGui::SetDefaultForResEdit( ) { return TRUE; } Bool grProgressBarGui::SetData( const TriState<GeData>& tristate ) { m_progress = tristate.GetValue().GetLong(); return InitValues(); } void grProgressBarGui::LayoutModeChanged( ) { } Bool grProgressBarGui::SupportLayoutSwitch( ) { return TRUE; } Bool grProgressBarGui::CreateLayout( ) { AddEditNumber( 25000, 0 ); return TRUE; } Bool grProgressBarGui::Command( LONG id, const BaseContainer &msg ) { return TRUE; } Bool grProgressBarGui::InitValues( void ) {
SetLong( 25000, m_progress ); return TRUE; } TriState<GeData> grProgressBarGui::GetData( ) { return GeData( m_progress ); } class grProgressBarDialog : public CustomGuiData #include "grProgressBarDialog.h" #include "grProgressBarGui.h" #define D_symbol "PROGRESSBAR" static LONG restypetable[] = { DA_LONG }; grProgressBarDialog::grProgressBarDialog( ) { m_properties.type = CUSTOMTYPE_END; m_properties.id = 0; m_properties.ident = NULL; } grProgressBarDialog::~grProgressBarDialog( ) {
} LONG grProgressBarDialog::GetId( ) { return 1000009; } CDialog* grProgressBarDialog::Alloc( const BaseContainer& settings ) {
grProgressBarGui* dlg = gNew grProgressBarGui( settings, GetPlugin() ); if ( !dlg ) return NULL; CDialog *cdlg = dlg->Get(); if ( !cdlg ) return NULL; return cdlg; } void grProgressBarDialog::Free( CDialog* dlg, void* userdata ) { if ( !dlg || !userdata ) return; grProgressBarGui* sub = static_cast<grProgressBarGui*>( userdata ); gDelete( sub ); } CHAR* grProgressBarDialog::GetResourceSym() { return D_symbol; } CustomProperty* grProgressBarDialog::GetProperties( ) { return &m_properties; } LONG grProgressBarDialog::GetResourceDataType( LONG*& table ) { table = restypetable; return sizeof( restypetable ) / sizeof( LONG ); }
On 15/09/2004 at 07:22, xxxxxxxx wrote:
ah, and I include it in my dialog by PROGRESSBAR IDC_PROGRESS_WIZARD { } and call SetLong( IDC_PROGRESS_WIZARD, 50 ); to set the value...but this call never reaches SetData
On 21/09/2004 at 12:41, xxxxxxxx wrote:
Most of your code looks right. I think the problem is that the dialog cannot use SetLong() with custom gui elements, only with built-in edit boxes and sliders. In a description you would be able to use your gui with a long. A workaround is to use FindCustomGui() and BaseCustomGui::SetData().
