On 21/08/2004 at 11:00, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.206 Platform: Language(s) : C++ ;
--------- Hi,
I want to include an Edit Slider widget in the AM of my ObjectData plugin. Looking at the SDK docs it gives this example:
EDITNUMBERARROWS MY_ARROWS_FIELD_ID { SIZE 100,0; SCALE_H; }
Using this causes an error when the AM shows on that line. It also happens with SLIDER. And yes I have that ID declared, just incase you ask.
Whats the problem?
Thanks
On 22/08/2004 at 17:29, xxxxxxxx wrote:
100,0 = 100.0
On 23/08/2004 at 02:15, xxxxxxxx wrote:
Thanks for the reply but even with 100.0, it still errors (infact that what I originally tried).
What I currently have is REAL IDC_PERCENT { MIN 0.0; MAX 100.0; STEP 1; UNIT PERCENT; };
All I want to do is turn that into a slider as default, so surely this would work.. EDITSLIDER IDC_PERCENT { SIZE 100.0; SCALE_H; }
but it doesn't
On 23/08/2004 at 07:08, xxxxxxxx wrote:
Oh this is in a description resource?! Well then it won´t work of course The slider is a customgui, so just add REAL IDC_PERCENT { MIN 0.0; MAX 100.0; STEP 1; UNIT PERCENT; CUSTOMGUI REALSLIDER}
On 23/08/2004 at 09:06, xxxxxxxx wrote:
Just for the record, "100,0" is certainly a valid SIZE for dialog resources. It means 100 pixels wide and default height.
On 23/08/2004 at 14:47, xxxxxxxx wrote:
Thank you, finally got it to work.
