On 10/08/2004 at 22:00, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hey all. I'm writing a tutorial on C.O.F.F.E.E. that includes a method for holding on to object level data from one iteration to another. In this case, it is the falling speed of the object that increases as time progresses. To remember the falling speed at the object level, I poke the last know value into the object's contatiner using: the_object_container->SetData(32000, drop_speed); On the next iteration, I read out that value, update it, and the cycle continues. Now, what I'd like to know is what data ID number range should I be using? I picked 32000 out of the air which is dangerous but ok for testing/learning. Suggestions? Thanks.
On 11/08/2004 at 06:01, xxxxxxxx wrote:
The best is to use a real unique ID from PluginCafe. The second best, for testing/learning, is to use a number in the range 1000001-1000010.
On 11/08/2004 at 19:29, xxxxxxxx wrote:
So plugin id's can be registered for this use? I though they were just for uniquely identifying a plugin. For now, I'll use the test range. Thanks
