On 29/07/2004 at 02:23, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.100 Platform: Language(s) : C.O.F.F.E.E ;
--------- Hi my name is Lars Quentmeier! Could someone please help me with a little coffe plugin? I would like to have a simple script that can loop through all frames and export each one seperately. A bath export skript, that simply loops through the animation and uses the normal exporters to write one file for each frame. That would be very handy for me! Thanks and Greetings from Germany Lars Quentmeier
On 29/07/2004 at 06:50, xxxxxxxx wrote:
I guess that what you are calling "a simple script" is pretty hard to do in COFFEE, if possible at all. It's definitely not a beginner's project and will need some serious knowledge of a couple of areas where you won't find examples or extensive documentation. When you have acquired the needed skills, then you would likely want to use the C++ API anyway.
I would suggest to have a look into the COFFEE examples first and try to explore the SDK starting from there with a smaller project.
Kabe
