SendModelingCommand doc?
    On 21/07/2004 at 12:27, xxxxxxxx wrote:
    Cinema 4D Version:   85
    Platform:   Windows  ;
    Hi - me again...
    I want to do a current-state-to-object in c.o.f.f.e.e., but I dont want an undo.... The sdk says that   SendModelingCommand  will generate an undo unless the document is omitted.  When I pass the doc, everything is fine, but if I pass a NULL ( instead of doc ) ,the object vanishes (along with its new copy).  Is there something that needs to be done AFTER the command  which could prevent the odd behaviour?  OR   is there a way to delete an undo without actually using it (so the doc could be passed, but the undo deleted)?
    Cheers mates.....
