Rotation XYZ
On 21/07/2004 at 03:45, xxxxxxxx wrote:
Cinema 4D Version: 6
Platform: Mac ;
Language(s) : C.O.F.F.E.E ;---------
BonjourI want to drive the rotation of an object (a bone) by the rotation of an other object (a bone) but I want to controle the rotation on X Y and Z independently.
I have write this :
main(doc,op){
var a = 1.00;
var b = 1.00;
var c = 1.00;
var tg = doc->FindObject("Os bras G"); if(!tg) return;var mo = op->GetMg(); //position globale de l'os tagué
var mt = tg->GetMg(); //position globale de l'os pilotevar Roto = mt->GetHPB(); //rotation globale de l'os pilote
var xo = RotX( ); // compiler : variable or function expected
var yo = RotY( );
var zo = RotZ( );var pos = mo->GetV0();
var scale = vector(vlen(mo->GetV1()),
vlen(mo->GetV2()),
vlen(mo->GetV3()));mo->SetRotX(xo * a);
mo->SetRotY(yo * b);
mo->SetRotZ(zo * c);mo->SetV0(pos);
mo->SetV1(vnorm(mo->GetV1()) * scale.x);
mo->SetV2(vnorm(mo->GetV2()) * scale.y);
mo->SetV3(vnorm(mo->GetV3()) * scale.z);op->SetMg(mo);
return;
}When I compile, on the line
var xo = RotX( );
it display : variable or function expected. I don't understand what I have to do.Bests regards
( Sorry for my english, I am french)
On 21/07/2004 at 05:10, xxxxxxxx wrote:
I make mistake in my post. The right expression is :
main(doc,op){
var a = 1.00;
var b = 1.00;
var c = 1.00;
var xo = RotoX( ); // compiler : varaible or function expected
var yo = RotoY( );
var zo = RotoZ( );var pos = mo->GetV0();
vlen(mo->GetV2()),
return;
}And my problem is on these lines :
var xo = RotoX( );
var yo = RotoY( );
var zo = RotoZ( );
On 21/07/2004 at 18:21, xxxxxxxx wrote:
Try this...
var xo = Roto.x;
var yo = Roto.y;
var zo = Roto.z;
On 22/07/2004 at 00:48, xxxxxxxx wrote:
Thank you for your response.
I try that before. No error of compilation and no error when I command "executate". But when I rotate the pilot bone around X axis the other bone turns around Z axis, when I rotate around Y axis the second bone turns only Z axis. In any way the second bone turns only around Z axis.
Bests regards
Damator
