On 30/06/2004 at 16:12, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.5 Platform: Windows ; Language(s) : C++ ;
--------- I am trying to write a text converting routine that would take Cinema 4D string and convert them to standard C++ strings (chars).
I have gotten some code from this forum that works well as long as I put it in the main execute section of the plugin. When I try to make a function/class/whatever its called out of it, it fails. Here is the code:
char ConvertString (String origString) { LONG len = origString.GetCStringLen(); CHAR* sqlStr = bNew CHAR[len+1]; return origString.GetCString(sqlStr,len+1); }
I call the function like exportfile << ConvertString(object->GetName()) < "\n". When I use this to write out to a text file, it doesn't work. If I take the exact same code and place it right before Im going to write out the text file, it works, for example:
LONG len = object->GetName().GetCStringLen(); CHAR* sqlStr = bNew CHAR[len+1]; object->GetName().GetCString(sqlStr, len+1); exportfile << sqlStr < "\n";
Can anyone help a newbie? Matt
On 30/06/2004 at 21:13, xxxxxxxx wrote:
GetCString() returns the length of the string, not the pointer to it. So your function should return sqlStr instead, and the type should be char*, not char. Note that you also have a memory leak to fix, since the string array is never freed. Perhaps you would find it easier to use std::string? (See the conversion functions in http://www.plugincafe.com/forum/display_topic_threads.asp?ForumID=4&TopicID=1046.)
On 01/07/2004 at 08:47, xxxxxxxx wrote:
I tried the std::String functions and couldn't get them to work correctly with the ofstream and << operator. I also know about the memory leak, but I didn't know how to fix it since I can't delete the sqlStr variable because I need to return it. How could I go about pluggin the leak in the function above?
By the way, if I return the sqlStr as you suggested, everything works fine. Thank you. Now if I can just plug the leak I will be in business.
Matt
On 04/07/2004 at 21:37, xxxxxxxx wrote:
That's weird, because std::string (note lowercase s) should be best friend with std::ofstream etc. Could you show an example? If your function cannot handle all of its memory itself, which it can't by your design, then you need to document this and make sure all users of the function free the memory for you.
