On 10/06/2004 at 05:29, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.207 Platform: Language(s) : C++ ;
--------- Hi, now I am trying to add a material to my scene. BaseMaterial * mat = BaseMaterial::Alloc(type); My problem is that the sdk does not give an explanation of "type" constants for the Material alloc method. Can anyone tell me what I have to fill in there? When I insert a 0 Cinema crashes afterwards when adding Information such as using setname etc. thank you
On 10/06/2004 at 06:11, xxxxxxxx wrote:
The constants are just the material IDs. There are a few defined in ge_prepass:
// materials #define Mbase 5702 #define Mmaterial 5703 #define Mplugin 5705 #define Mfog 8803 #define Mterrain 8808 #define Mdanel 1011117 #define Mbanji 1011118 #define Mbanzi 1011119 #define Mcheen 1011120 #define Mmabel 1011121 #define Mnukei 1011122
On 10/06/2004 at 08:20, xxxxxxxx wrote:
Hi, okay that worked but now for the next problem: TextureTag * tag = static_cast<TextureTag*>-(object->MakeTag(Ttexture, NULL)); tag->SetMaterial(mat); tag->SetName("Set by GroImp"); EventAdd(EVENT_FORCEREDRAW); assuming everything with the object and material went ok. So why does my Object that I assigned the tag to get invisible? Furthermore I cannot see the Tag in the Object browser... Any idea? Thank you...
On 14/06/2004 at 23:45, xxxxxxxx wrote:
Hi, I think, you must at first insert the material into the active document. (e.g. GetActiveDocument()->InsertMaterial( mat ); )
