SplineObject control points
On 09/06/2004 at 13:01, xxxxxxxx wrote:
Cinema 4D Version:   8.100
Platform:
Language(s) :   C.O.F.F.E.E  ;  C++  ;
I am developing a plugin which creates (cubic or bezier) spline objects.  I can create and insert the spline object with the on-curve points, but I do not know how to enter the off-curve points.
Thanks
On 10/06/2004 at 01:23, xxxxxxxx wrote:
What do you mean by off-curve points? Tangents? That's done with spline->GetTangent().
On 10/06/2004 at 09:26, xxxxxxxx wrote:
Yes, thank you.  I found a valid tangents array only when the curve type was set to Thermite.
On 10/06/2004 at 14:05, xxxxxxxx wrote:
Is there a good tutorial for creating splines with multiple loops?  Such as the splines created when importing an illustrator document?
