On 14/05/2004 at 04:02, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.5 Platform: Windows ; Language(s) : C.O.F.F.E.E ; C++ ;
--------- Hi. I have written a function in COFFEE to check that a object really exist in the current document(dont a "ghost" object). Is this function needed in C++?
Code of coffee function:
// ***************************************************************************** // Test, if the object realy exist or not in the current document // Input: // objMain: object to test // Output: // bool: TRUE, if the object found, else FALSE // ***************************************************************************** boObjectExist (objMain) { var docMain; if (typeof(objMain)!=DT_OBJECT) // object dont exist { return FALSE; } else { docMain= objMain->GetDocument(); if (!instanceof(docMain, BaseDocument)) // is the doc realy a document? { return FALSE; } else if (docMain->FindObject(objMain->GetMarker())) { return TRUE; } else { return FALSE; } } }
On 14/05/2004 at 04:32, xxxxxxxx wrote:
Not sure if this is necessary at all. If you pass an object pointer and this one is a null pointer then it means the object doesn´t exist. Same goes for COFFEE. Maybe I am misunderstanding it?
On 14/05/2004 at 06:05, xxxxxxxx wrote:
Hi. Thx for answer. This was helpful.
