StrNotFound as TagPlugin name
On 13/05/2004 at 05:49, xxxxxxxx wrote:
Cinema 4D Version: 8.500
Platform: Windows ;
Hi.I programmed a simple tag plugin.
Everything seems to be ok, but the tag name in expression tags menu is "StrNotFound Expression".
On 13/05/2004 at 20:30, xxxxxxxx wrote:
That could be a problem with the string resource. Make sure that you've prepared your string resource in accordance with the documentation and the example project.
On 13/05/2004 at 23:16, xxxxxxxx wrote:
Hi. Thx for the answer.
My c4d_strings.str was named before as c4_strings.str .Ok, now it work.
